CSV Trim Spaces
Is there a function or another way to trim spaces for incoming CSV files.
Can you expand your use case? Does the CSV comes in via FileListener?
Regards
Simon
Yes it comes in thru listener. It then gets parsed. When it parses some of the data has spaces that need to be trim in the front and back of each value.
HI,
Below link might help you.
https://www.codeproject.com/Questions/797603/How-to-remove-extra-spaces-from-CSV-file-exporting
Is there away in PEGA instead of SQL
Could you please explain how are you getting your csv data.
