Veteran Careers First
Last activity: 7 Sep 2018 11:39 EDT
round decimals
I have a requirement to round decimals
Ex.
- If decimal less than 50 (ex. 19.20) then round to 19
- If decimal greater than 50 (ex. 19.60) then round to 20
Any ideas
Tekclan solutions
There is OOTB function in pega @round(.Property). Use this in data transform to set the property value and configure event action for the property.Set Event as click and Action as Refresh then specify the created data transform into it.On Execution when the value is entered and click action is performed it gives the round of value.
do review similar posts here
https://collaborate.pega.com/question/decimal-precision-editable-format
https://collaborate.pega.com/discussion/how-round-value-decimal-property-certain-precision-point
Praveen Reddy
Vodafone
Hello Henry,
We don't have Pega OOTB feature to fix reported issue, as an alternative you can achieve this in using custom Java logic .
1. onChange of property value call an activity, fetch the property value (this.value) and use Math.round logic in activity java step.
Cheuk Yi Mak
Tata Consultancy Services
Below link might help you.
PEG
If it's a pure Java step
(D + .5) % 1
Tekclan solutions
Josué Menjivar
CollabPartnerz
You can use Math.round logic method inside an activity to set.
CollabPartnerz
Have you tried with math.round functions.
You can also use the Edit Input Rule to do the same.
java.text.DecimalFormat f = new java.text.DecimalFormat("##");
theValue=f.format(d);
Can you provide steps on how to implement
