How to change background colour in portal header
I have located the blue colour in portal header in a Skin rule and want to change it to our customer's corporate colour. Containers > Portal header > Content > Background:
When I change this "Mixin" I confirmed that the background colour is changed as expected. Now I want to specify a specific HTML colour code. I am not sure what this "Mixin" is, but where can I enter the HTML colour code? Or should I do that in somewhere else?
Mixin is re-usable component with specific html attributes that can be used across your skin components(like layouts, headers etc..)
To create a new mixin.
1. Go to Mixin tab in your skin rule.
2. Under Backgrounds add a new mixin.
3. You can specify the hexadecimal colur code in there or select the required color from the color picker. save it. Refer my screenshot
4. Refer the newly created mixin in your portal header background mixin.
Another Approach:
Instead of creating the mixin you can also select the option "Specify Styles" (as shown in your screenshot). And then can specify all the HTML attributes there itself.
But creating a new mixing is a cleaner approach and is suggestable.
