How to generate HTTP end point url in soap
Hi Team,
How can i generate HTTP end point url instead of https in soap integration.
Regards
Pavani
Hi Team,
Regards
Pavani
Using below three ways :
1.EndPoint URL can be configured in prlogging.xml
for eg: <param name="EndPointURL" value="http://sdevrulesb:8888/prweb/PRSOAPServlet"/>
2.Define in "Declare Pages" in real time.
3.You could make use of global resource settings for configuring endpoint URLs.
Refer the below pdn article for more details on the configuration
Hi Chandra,Thanks for the information, i will go through the link and get back to you
