DropDown
HI All,
I need a help from you all. I have 2 dropdowns with same options like option 1, option2, option 3 , option 4 and option 5 and dropdown class name is "Source". Default option is 'select one'.
If 'option 1' is selected in any of the dropdown , that option should be hidden from Destination dropdowns.
If I de-select the selected option ('option 1') , that should be visible again in all the dropdowns for selection. Can someone help??
I want to achieve it using pega
Hi Siddava,
Thanks for posting on PSC.
It can be leveraged in Pega,
Steps:-
1. Create two Value/Page Lists as per your business requirement.
2. In the first drop-down, source it first ValueList/PageList property to load the content. ValueList1/PageList1 and ValueList2/PageList2.
3. Configure an action set with "OnChange" event and "Refresh-This Section" event on the first drop-down (Assuming this section having both the drop-downs). In the refresh event, configure a data transform to populate the data from ValueList1 by copying or appending in the second "ValueList2/PageList2" with filtering and skipping the copying of the selected input value in the first drop-down.
Hope it gives you the high-level idea to implement the use-case at your end. Kindly notify if it does by marking this post as answered for larger Pega audience and tracking purpose.
Asif
