Coforge
Last activity: 28 Sep 2017 20:03 EDT
Group by in Report definition not allowing more than one column
I have a requirement to filter the results retrieved by report definition to get top ranked 1 row based on 3 columns.
Unfortunately in report definition for group by there is only one column is allowed.
I have attached the screen shot for reference.Please verify and provide your inputs and solution if any.
Note: We are using Pega version 7.2.2
Thank,
Giri
Hi Giribabu,
Your requirement is not clear. But if you want to use more than 1 property then you need create a function or use existing function as per your requirement and call that function from calculation builder
