SQLState: 08001 Message: No suitable driver found for jdbc:oracle:thin:@localhost:1521:orcl
I am getting below error while connecting to an external Database Oracle 11g which is installed in my local PC.
I have verified the jdbc driver, it is already present in "C:\PRPCPersonalEdition\tomcat\lib" and I have modified the PRConfig XML as well
"<env value="com.microsoft.sqlserver.jdbc.SQLServerDriver;oracle.jdbc.OracleDriver" name="database/drivers"/> ".
you should not have to touch OOTB prconfig.xml, add the jdbc jar file under tomcat/endorsed directory (create one if not already there), restart the server, you should be fine.
