Does Pega timeout sessions based on < session-timeout > setting of web.xml? [7.2.2]
I added a configuration of <session-config><session-timeout>3</session-timeout></session-config> in web.xml, and left more than 3 minutes. However, I can keep operating without re-login. Does Pega timeout sessions based on <session-timeout> setting of web.xml?
Jun
There are two timeouts and two behaviors to consider. All are controlled by configurable system settings. The settings are not included in standard dynamic system settings or prconfig.xml
- authentication timeout -- time after which an operator will be prompted to re-verify credentials (user/password)
- requestor timeout - timeout after which the requestor is freed from memory and "passivated"
Default behavior of Pega 72 is to "passivate" a requestor by storing it in the database, where it is available for "activation" for 24 hours or longer until the systemCleaner agent deletes it. Passivation may be changed to "disk" passivation or "never" - once freed it is gone.
Default behavior of Pega 72 is to not authenticate on activation -- if there is a submission from browser with appropriate PegaRULES session cookie, the requestor is automatically activated (loaded back into memory) without challenging the user for credentials.
Default requestor timeout is 3600 seconds - one hour.
References:
https://pdn.pega.com/documents/authentication-pegarules-process-commander-v53
https://docs-previous.pega.com/configuration-settings-reference-guide-prpc-5x-prpc-62
