Rabobank
Java. lang. null pointer exception
What could cause the Null pointer exception (mostly getting for Section rules and for other rule types as well)? and mostly these are being thrown for OOTB rules.
Version -- 7.2
Thanks.
Hello!
On reviewing the corresponding SR, it is determined that the root cause of the issue was with an OOTB rule present in the application RuleSet. This has been rectified and thus resolved.
Hi Srini,
Can you please share the logs containing this NullPointer to review the exception trace?
Hi SriniAncha,
The NullPointerException stack in the log will tell you where exception comes from. The root causes are varies.
Susan
Pegasystems
It looks like this has been reported as SR-B33683 .
(Should we always inform each other if we've reported our issue in an sr?)
Hello!
Optum - (UHG)
Hello, We are experiencing multiple Java NullPointer exceptions as well. This was discovered in our perf testing in our STG Env.....Can someone help?
Heres the log msg from the excpetion logs:
[2/1/18 3:23:35:731 CST] 000000a5 SystemOut O 2018-02-01 03:23:35,730 [ WebContainer : 1] [TABTHREAD1] [ ] [ MIIM:02.08.01] ( internal.mgmt.Executable) ERROR miimstg.uhc.com| Proprietary information hidden miimpt11 - Exception
java.lang.NullPointerException
at com.pegarules.generated.activity.ra_action_runflowactionactivity_58efc1b6f854c94714f657cadaebe7ff.step3_circum0(ra_action_runflowactionactivity_58efc1b6f854c94714f657cadaebe7ff.java:379)
at com.pegarules.generated.activity.ra_action_runflowactionactivity_58efc1b6f854c94714f657cadaebe7ff.perform(ra_action_runflowactionactivity_58efc1b6f854c94714f657cadaebe7ff.java:103)
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3505)
at com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity(Executable.java:10553)
at com.pegarules.generated.activity.ra_action_performpreprocessing_09a325f67bf9b651644b077408ec0712.step10_circum0(ra_action_performpreprocessing_09a325f67bf9b651644b077408ec0712.java)
at com.pegarules.generated.activity.ra_action_performpreprocessing_09a325f67bf9b651644b077408ec0712.perform(ra_action_performpreprocessing_09a325f67bf9b651644b077408ec0712.java:244)
at com.pegarules.generated.activity.ra_action_processaction_ecfb18bfff74b732e0d3ef9acc18243a.step18_circum0(ra_action_processaction_ecfb18bfff74b732e0d3ef9acc18243a.java:1899)
at com.pegarules.generated.activity.ra_action_processaction_ecfb18bfff74b732e0d3ef9acc18243a.perform(ra_action_processaction_ecfb18bfff74b732e0d3ef9acc18243a.java:353)
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:646)
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivitiesAlt(PRThreadImpl.java:461)
at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.runActivities(HttpAPI.java:3358)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequestInner(EngineAPI.java:385)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:95)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:56)
at java.lang.reflect.Method.invoke(Method.java:620)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1270)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1008)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:841)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequest(EngineAPI.java:331)
at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.invoke(HttpAPI.java:852)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:315)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:263)
at com.pega.pegarules.session.internal.engineinterface.etier.ejb.EngineBean.invokeEngine(EngineBean.java:225)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:370)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:411)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingException(AppServerBridgeToPega.java:245)
at com.pega.pegarules.internal.etier.ejb.EngineBeanBoot.invokeEngine(EngineBeanBoot.java:168)
at com.pega.pegarules.internal.etier.interfaces.EJSLocalStatelessEngineBMT_f2439d86.invokeEngine(Unknown Source)
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngineInner(JNDIEnvironment.java:278)
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngine(JNDIEnvironment.java:223)
at com.pega.pegarules.web.impl.WebStandardImpl.makeEtierRequest(WebStandardImpl.java:574)
at com.pega.pegarules.web.impl.WebStandardImpl.doPost(WebStandardImpl.java:374)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:272)
at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doPost(WebStandardBoot.java:121)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:595)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:668)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1232)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:781)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:480)
at com.ibm.ws.webcontainer.servlet.ServletWrapperImpl.handleRequest(ServletWrapperImpl.java:178)
at com.ibm.ws.webcontainer.filter.WebAppFilterManager.invokeFilters(WebAppFilterManager.java:1114)
at com.ibm.ws.webcontainer.servlet.CacheServletWrapper.handleRequest(CacheServletWrapper.java:87)
at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:940)
at com.ibm.ws.webcontainer.WSWebContainer.handleRequest(WSWebContainer.java:1817)
at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.java:200)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimination(HttpInboundLink.java:463)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewRequest(HttpInboundLink.java:530)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.processRequest(HttpInboundLink.java:316)
at com.ibm.ws.http.channel.inbound.impl.HttpICLReadCallback.complete(HttpICLReadCallback.java:88)
at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted(AioReadCompletionListener.java:175)
at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFuture.java:217)
at com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(AsyncChannelFuture.java:161)
at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:138)
at com.ibm.io.async.ResultHandler.complete(ResultHandler.java:204)
at com.ibm.io.async.ResultHandler.runEventProcessingLoop(ResultHandler.java:775)
at com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:905)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1881)
Rajana Ashok Kumar
