Issue in joining sub report in main report
I am creating one Report Definition and calling one sub-report inside it. In the sub report I am taking count of a column. When I am running the sub-report stand alone then it is giving the correct count. But when running from the main RD, it is showing all the counts of the main report, not particluar count of that sub-report. I have changed the joing conditions in the sub-report configuration as all rows from sub report, but still not wokring. Could you please help me.
Hi Saikat,
Did you try using JOIN instead of Sub Report. You can get the count of Table B using Outer Join.
Normally the report would be ran on the main table. Hence not sure for the above scenario Sub report is the right approach. May be you can ellaborate more on the scenario.
Shahjahan.
