Iriz Consulting
FR
HTTP Status 404, Tomcat error
Since this morning, I'm not able to access Pega from my browser. Launching the Virtual Machine on VirtualBox and access the URL from Chrome triggers the following error:
HTTP Status 404 - /prweb/PRServlet
type Status report
message /prweb/PRServlet
description The requested resource is not available.
Apache Tomcat/7.0.53
From the manager, it seems that /prweb is not running, and trying to start it give me the following error: FAIL - Application at context path /prweb could not be started
Is there a way to fix it? Thanks in advance.
Updated: 6 Oct 2016 10:05 EDT
Iriz Consulting
FR
Ai4Process
did you modify anything in tomcat or postgresql configuration?
Damien
I do not mean to interrupt Damien, but you could also check the status of Tomcat in the vm.
Login to the VM console with:
user: root
password: install
then, enter this command: service tomcat status
you should get back something like: Tomcat is running with pid: nnnn
let us know how it goes.
eddie
Hi Thomas,
Has your issue been resolved or do you still require assistance?
-Maryrita Styer
Community Manager
Iriz Consulting
FR
Sorry for replying late; I fixed my issue by reinstalling all my virtual machine with the same file, but re downloaded from the webiste.
Regards.
Commonwealth Bank of Australia
I am getting the below page when I launched the virtual machine on VMware with chrome browser.
OVA file : PegaFundamenals_716_2016_10_24
Is there a fix for the below issue?
Thanks in advance
HTTP Status 404 - /
type Status report
message /
Thanks in advance
HTTP Status 404 - /
type Status report
message /
Apache Tomcat/7.0.72
RHMC Consulting Ltd
I have the exact same problem as WilliamT9679
Exact Same build of the Fundamentals VM
Exact Same mesage for Tomcat
Following the infomation on this thread I have logged into the VM and run the "service tomcat status" command, the response is "Tomcat is running with pid: 1721"
Any help would be appreciated
SG
Look at the Tomcat Manager http://<ip>:<port>/manager and see if the /prweb resource is started. If not, start it up. If it cannot be started, I suggest to follow the OP's solution and re-extract a new copy of the PVS.
* for the login credentials to Tomcat Manager, try admin/admin or admin/password.
I have installed personal edition 7.2.1 both admin/admin and admin/password are not working for my tomcat manager. Please help if you know any new combinations for 7.2.1.
try username: admin
password: install
Bill Rathert
TATA Consultancy Services Ltd
I am facing same issue can you please help
i am facing issue , can you please help.
SG
Have you tried using my solution above, i.e. going to Tomcat Manager (http://<ip>:<port>/manager) to see if the prweb application is running? If you're still unable to resolve, I suggest that you just restart from scratch again with a new .ova from Pega Academy.
I am getting below error
HTTP Status 404 – Not Found
Type Status Report
Message /prweb/PRServlet
Description The origin server did not find a current representation for the target resource or is not willing to disclose that one exists.
Apache Tomcat/8.5.14
i am getting below error in error section
SG
Please provide the following information:
- Name of the course:
- Filename of the VM (*.ova):
- Virtual machine used: VirtualBox or VMware Player
- Screenshot of the VM login screen
- Screenshot of the "ping" output from your host to the VM
Hi Chuat ,
I have reinstalled Pega not i nt facing this issue .
Currently i'm not able to login VM
I am getting HTT404 not found error.
please help me on this
SG
I am not sure I understand what you mean. Please do reply to my questions in the previous post first, so I can understand what course you are working on, and the name of the exercise VM you have installed. If you are not using the Pega Academy exercise system, then you may need to contact GCS or whoever you have obtained the VM from.
I reinstalled Pega , Still I am facing same issue.
Getting below message in TomCat while starting the prweb.
Message: |
FAIL - Application at context path /prweb could not be started |
SG
What course PVS are you working on? Check the Tomcat log files and see if you can identify what is the reason why /prweb cannot be started. If you are unable to resolve it, I suggest you contact [email protected] with details of the problems and what steps you had taken so far.
American International Group Inc
The VM machine instructions and the VM console appear to be misleading to me. I'm a manager taking this training to learn about Pega.
The right link is "http://nnn.nnn.nnn.nnn:9080/prweb" and not "http://nnn.nnn.nnn.nnn:9080". It took me a while to figure out and thankfully, I found this thread. The PDF as well as the VM console should be updated to say "Open browser in your computer....(http://nnn.nnn.nnn.nnn:9080/prweb)".
Regards.
