Nordea
Nordea
SE
Nordea
Posted: Sep 19, 2016
Last activity: Oct 13, 2016
Last activity: 13 Oct 2016 10:43 EDT
There is an ask to generate chart/report data in PPT format. as far as i know, pega supports Excel and PDF format out of the box. Is there a way to generate the report data in PPT format as well?
Hello
As of now, we dont have any such out of the box solution. You need to write your own logic to convert your HTML stream to PPT.
You can use Apache POI and refer code here for example
Thanks for the response Santanu. Is there a way i can pass the section name in place of passing HTML?
I dont think we can pass section names. I tried but it does not work.
