Philips
Philips
Philips
Posted: Aug 29, 2016
Last activity: Sep 2, 2016
Last activity: 2 Sep 2016 5:46 EDT
Is it possible somehow to construct query in report defenition with info from Decision Table or Map rule?
Maybe it possible to write custom User Function that will evaluate Decision Table?
Of cause I can write User Function equivalent, but I not gonna do it. For example I can delegate Decision Table to end user, but User Function - no, I'm not willing to do that
Would you be able to access the info you need through a function alias? If you can code the equivalent query for the decision table in a function alias, you can include the result in a report definition.
