Government of Canada
Last activity: 25 Nov 2024 15:54 EST
INSTALLING AND CONFIGURING ELASTIC SEARCH ON PEGA INFINITY 24.2 WITH VM ONSITE CLIENT MANAGED
I appreciate if the below questions are answered
1. Can we configure External Elastic search without PEGA SRS? If Yes what are the configuration parameters. (Please provide some detail on configurations like what change to make in web user node and search node)
2. If the answer is no to the above question then --> Is PEGA SRS available to download for VM install ? Not the docker version ?
3. Documentation for installing and configuring external/internal search is inadequate, appreciate if there is a good documentation which can be shared.
Appreciate your response.
Thank you
@AnandS0631 can you confirm if you have gone through the available documentation?
you cannot configure External Elasticsearch without Pega SRS. The Search and Reporting Service (SRS) is required to manage communication between your Pega nodes and your preferred Elasticsearch service. SRS can be provisioned using a Pega-provided Docker image. For VM-based installations you can find instructions on how to connect to SRS and configure it appropriately.
You can refer to the documentation on configuring search which describes how to create search indexes and configure search for Help sites Community sites and the Customer Service Interaction Portal. This documentation is available for versions 24.1 and 24.2 of Pega Knowledge. Here are the links: Configuring Search for version 24.1 and Configuring Search for version 24.2.
External Elasticsearch in your deployment
