SkillStorm
Last activity: 3 Jul 2025 7:07 EDT
How Do You Customize Approval Button Labels in Constellation?
In my case type, a customer must enter a verification code to access their profile. I found that by using an approve/reject step and a decision object, if the customer fails to enter the correct code, I can give them the option to go back and try again, loop around and get a new code, or continue as a guest.
I would like to customize the buttons on the approve/reject step to reflect this functionality. In particular, change:
- "Approve" to "Continue" or "Continue as Guest"
- "Reject" to "Request new code"
- (tentative) "Previous" to "Try again"
Normally you can change the button text by editing the flow action, but approve/reject steps have no associated flow action, only a view.
Is there any way to achieve this OOTB in Constellation?
