hkr
Last activity: 23 Sep 2024 10:50 EDT
Okta apps validation
I have 3 okta apps setup.
- Okta app for backend
- Okta spa app
- Okta web app
The Okta spa app is able to use the access token it got and pass to Okta app for backend and the token is validated. However, the Okta web app access token when passed to Okta app for backend, could not be validated, thus token is not valid.
Anyone know the proper setup for the Okta web app so where its access token can be validated against the Okta app for backend?
@hemanthb17091501 Based on the context provided the configuration described in the article 'Configuring Pega Mobile Client to authenticate against Okta' should work for both web and mobile. The fact that you choose 'native' type of integration in the Okta console does not prevent it from working in web. You might want to review Step 4 in Part One of the article to ensure the setup is correctly tested with a desktop.
Troubleshooting OpenID Connect (OIDC) integrations
