JBoss EAP 6.4.x with Java 8
I need a clarification about the following question regarding the support of Red Hat JBoss EAP 6.4.x (using Java 7 or 8).
It is not clear if it is also supported version 8, though it is wrote so on page 6 of the Pega 7.2 platform-support-guide.pdf.
Because then on page 12 there is this note:
11. JBoss does not bundle a JVM in its application. Pega recommends Oracle Java 7, at
the latest level ( 'unless it is Specifically That Stated That level does not run with Pega
7). See Note # 2 above for information on the latest Oracle Java 7 levels.
So the question is:
is JBoss EAP 6.4.x with Java 8 supported or not ?
Thank You
Hi Eugenio,
As of Pega 7.1.8, Oracle Java 8 is supported.
JBoss EAP 6.4 is supported since Pega 7.1.9 both with Java 7 and Java 8.
For more details please refer to the Pega 7 Platform Installation Guide for Pega 7.2:
https://docs-previous.pega.com/pega-72-platform-installation-guide-jboss-and-oracle
Kind regards,
Domenico
