Software Improvement Group
Posted: Jun 28, 2024
Last activity: Jul 5, 2024
Last activity: 5 Jul 2024 10:17 EDT
Export format of Pega applications
I have tried multiple ways of exporting a Pega application, Pega 8 onwards. One way was this one, for example: https://academy.pega.com/challenge/exporting-application/v3
My question is about the export format, the contents of the JAR or the ZIP. It contains metadata, schemas in XML format and .bin files. I was wondering if there is a way to get the rules/application logic in XML (or any other textual format) instead of binaries.
Thanks.
@BugraMY17195992 When you export a Pega application, the product rule creates a .zip file by default. This .zip file contains rules.jar and schema.jar. The schema.jar contains XML for different tables which can be easily read and interpreted. The rules.jar contains binaries and cannot be opened outside Pega. The rules/application logic is stored in these binaries and there is no out-of-the-box way to export them in a textual format like XML. This is done to ensure the confidentiality and integrity of the application rules.
Create Pega Product File - RAP Type - Best Options in terms of performance an
Exporting an application, product rule, or ruleset to an archive or repository by using the Export wizard
How to export survey from one application to another?
Packaging your application in a product Rule
