How to change the Tab icon in Customer Service application
I'm trying to change the tab icon for my custom data source interaction, similar to how Account related interactions use a custom icon and label in Customer Service:
However, only the default task or check icon shows up for me:
I have checked the clipboard for the following properties: (set in data transform "SetInteractionDetails")
- .CSTabTitle, I set the custom tab name, e.g., "ReqG. addd" but I noticed the tab did not pick the value, only if I set a declare expression on property pyDocumentTitle, then it works.
- .InteractionTabIcon, I have tried setting values used for ootb contact or account, e.g., "pcs-research-contact pi-tab-icon" or "pcs-research-org pi-tab-icon" but it does not work.
Thanks for any help on this,
-Jose
***Edited by Moderator Rupashree to add Capability tags***
@josenavas
We need to modify it in the respective datatransform based upon the channel ,
If it is call interaction then we can make the changes in the SetInteractionDetails PegaCA-Work-Interaction-Call class , tab icon will come as phone call.
If it is a chat interaction , then these details are set in the SetInteractionDetails PegaCA-Work-Interaction-Chat class and setHeaderIcon DT. tab icon will come accordingly with respect to the channel (facebook or web messaging or sms) .
Thank you
