Spell Check as you type
My Client has a requirement to have Spell Check work in a Rich Text box as they type - not by clicking the built-in Pega Spell Check button.
I did find this option using custom Java code, and tried it, but it didn't work
https://support.pega.com/question/auto-spell-check-feature
Next i turned off the built-in Pega Spell check, and tested to see if the Browser Spell check works.
For some reason it works OK in some fields and not others E.g
It works in the To:, Cc and Subject fields (see red wavy lines), but not in the body text box. No red wavy line appear whilst typing.
How can I get this to work?
This is in Chrome, but will probably also need to work in Edge.
Ironically, the feature I need seems to work in this very text box that I'm typing in now, which I assume is based on Pega Platform! Although if I right click on a misspelled word, i only get the option for Paste rather than a list of corrections. Yay.
***Edited by Moderator Marije to add FDBK tag***
As this has had no replies, I'll close off the User Story I have for this and assume it's not possible and put it down to a Pega limitation.
