Error Fail pyaccessgroup
Hello ,
i have a requirement that in my validation rule check if the property pyAccessGroup contains this list return false i try with this expression but it dosents work , how i can implement this if there are any solution
@contains(pyAccessGroup,"AUTHORS","SYSADMIN","AUTHOR","SysAdmin","Authors","AppSetup","ChannelManager",false)
Regards
***Edited by Moderator Marije to change Content Type from Discussion to Question; change type from Pega Academy to Product, added capability tags***
@marwab91 I can think of two ways to doing this:
1. convert the values into a pagelist use ootb function pxPageListFromStringCSV) and PageListContains to check for the value.
2. Make use of a decision table
