Need to Use HS512 algorithm whilecreating JWT tokenprofile in pega8.
We need to integrate with external system from Pega 8.3.2 using Jason Web Token (JWT). In Pega Token Profile (DATA-ADMIN-SECURITY-TOKEN) instance, we can only select asymmetric algorithm attached below:
Customer's requirement is HS512 - that is one of a symmetric algorithm and that is a must. Is it possible to easily make it available...
I had the same problem until 8.3 version Pega supports only asymmetric algorithm to generate tokens, since HS512 is a HMAC and uses symmetric algorithm and you cannot use. In 8.4 version, Pega Token Profile has both asymmetric and symmetric option.
