Thryve
Last activity: 1 Mar 2021 21:33 EST
Refresh section is not refreshing the Repeating Layout contents
Requirement :
We have requirement to revert the change made in drop down(in repeating layout) on click of 'Reset' button. Button is configured outside of RDL , but within same section.
Attempted soln :
1.We have tried Refresh section action set on click of button, which is not working.
2. We have tried placing dropdown in separate section and used Refresh-other section which is also not working.
Pega version : 8.4.1
Please share your thoughts on mitigating above issue. Thanks!!
@PonnurangamN6839
Should you just Property-Remove the value from the clipboard and redisplay the harness maybe? What do you mean by not working exactly?
