@String.whatComesBeforeFirst() not working
***Edited by Moderator: Pallavi to change content type from Discussion to Question***
Hi
I am facing the same issue.
Could you please help us with the correct format?
Jashwanth
What are you trying to do and what is the error you see?
You can see a sample for the format on the following link.
Hi
As per the usage of @whatComesBeforeFirst(String,char), it takes String and character as arguments but you are passing string "I-" which is not vailid as per the usage.
Below is the usage
