What is the significance of "Inherit privileges within class hierarchy" in ARN ?
I could see this check box on Access Role Name, I am not sure about its significance.
What i tried is , Class A has 1 ARO Class B has 1 ABO as part of same ARN. Now both of them has 1 Privilege rule each. And class B is inherited from class A.
I am able to set Privilege rule of Class A in ARO of Class B, irrespective of "Inherit privileges within class hierarchy" check-box checked or un-checked.
Not sure if i am missing something here.
I read somewhere "an option on the role for inheriting privileges within AROs defined in the class hierarchy. Selecting this option provides the user with all privileges in the class hierarchy for AROs and user roles."
So with that said, is this statement holds true for runtime behavior ? as i do not see anything changing in design time with/without checkbox checked.
