Infosys LTD
BE
Last activity: 17 Feb 2021 10:12 EST
Taking User Input from Table(Dynamic Repeating Grid) control in section 7.4
Problem Statement: I am trying to take multiple inputs at run time in form, from Table control in section in Pega version 7.4.
Steps:
1) I have created a data class : TGB-HRApps-Data-Dependents
2) I have created three properties in it. (Item name, Item Quantity, Item ID)
3) I have created a Page list type property in my work class: TGB-HRApps-Work-BenefitsEnrollement with Page definition of class TGB-HRApps-Data-Dependents.
4) I have created a section AddItems in Work class ABC-BPM-Work-Sales .
5) In above section i have dragged a Table control from Layout pallete which comes under Row/List based layouts. This table control comes with default Add and Delete buttons on top.
6) In this table control I have defined data source as Property and in List/Group filed i have given my pagelist property DependentPL. Now i have dragged two text input field from pallete for which i have mentioned the property pyFirstName and pyLastName.
7) When i create a work object and at run time when this section is rendered and when i click the default add icon nothing gets added to my Page list.
While this implementation works perfectly fine in 7.1.8 , can someone help me about how to implement this in 7.4
Please find attached screen shots
I have found the answer for my problem. Below is the approach
1) Open your section rule.
2) Drop a Table control from layout pallete .
3) Click on the settings icon on section , a pop up for layout properties will appear .
4) In pop up go to Operations tab for row editing select inline and for inline edit mode select Rows always editable.
