Sberbank
UA
Last activity: 18 Apr 2017 23:01 EDT
Difference between PageList, ValueList and Code-Pega-List.
Hello, everyone. I have run into a question about differences between PageList/ValueList and Code-Pega-List.
I know that
1) ValueList is a group of elementary type elements, which has unique index.
2) PageList is an indexed group of complex elements.
But what about class Code-Pega-List? Where I am allowed to utilize it?
When I was researching that question, I found out, that PageList or ValueList property cannot be passed as parameter where is awaited Code-Pega-List type property.
P.S.: I apologize about mistakes. If you have find one, please point it out in your answer.
Thank you.
Code-Pega-List is a class. When you use a list type page in your code, the class of that page should be Code-Pega-List. Suppose you are using a page which holds list of products. Then in Page And Classes tab declare the page with class Code-Pega-List. While using each element use syntax ProductList.pxResults(i) to access individual page of that list. pxResults is a Page List type property of Code-Pega-List class.
