Student
Student
Student
Posted: Apr 11, 2025
Last activity: Oct 1, 2025
Last activity: 1 Oct 2025 11:11 EDT
PDF Pages need to be split into different different pdf's
There is a PDF with 5 pages. These 5 pages need to be split into 5 separate PDFs — one page per PDF. please give me solution for this.
@VENKATESHV4213 To split a PDF with 5 pages into 5 separate PDFs (each containing one page), you can use the "PDFBox" Java library or an automation tool like Power Automate or Python script with
PyPDF2. Here's a simple approach using Python: install the PyPDF2 library (pip install PyPDF2), then write a short script to read the PDF, loop through each page, and write each page into a new file. This will create 5 separate files named likepage_1.pdf,page_2.pdf, etc. This method is efficient, works offline, and doesn't require manual splitting or external paid tools. Let me know if you’d like the script.
