Weblogic application server integration with Websphere MQ.
Our requirement is to integrate Websphere MQ server with our web application which is deployed on Weblogic server. I understand that for this we need to enable Websphere MQ support which requires to install the MQ client on Process Commander.
Is there any article or document which provides an elaboration on how to install the MQ client on PRPC and the subsequent configurations in weblogic & pega to add MQ jar files to the Process Commander compile time and runtime class paths?
On another note, we also need to implement the automatic failover handling scenario in case the primary MQ server is not available or has been taken down for maintenance. In such a scenario, the system should automatically switch to the secondary MQ server. Does this configuration have to be done in Weblogic server?
Best Regards
Sovan
