String var value in different automation flows
I've 3 string vars, one for three different flows, that feed another string var (that feeds a switch case).
The point is that:
- if automation flows through var8 (please see img), it works as expected that is var9 = var8
- if automation flows through var10, var9 = var7 = var8 = <default var value> and not var9 = var10 as expected
I can't understand why, since automation links takes different flows.
Is there any reason or possible error?
