CBA
How to enable record test
I am trying to enable the record test case for unit testing.
Can someone help with steps how to enable for latest version?
I found article which is on Pega 5 version. Please let me know.
Updated: 14 Jun 2021 7:38 EDT
JP Morgan Chase & Co.
Are you looking for a Record Test case option for Case Type, if yes it would be available when we open the case designer in the Dev Studio.
CBA
I need steps -- is there any specific Ag and Privilege i need to add I am looking for those steps to enable the feature
If you log in with the developer role, I think this should be visible. Is it not happening in your case.
CBA
Yes Kanap2, PFA
Record test case would be available in the Case Designer. Please find the below screenshot for more details.
CBA
Thanks Kanap2 for the reply, I can see that in a cloud instance, but how to implement in the personal edition or application.
Does actual requirement----want to enable record test feature in my enterprise application how to achieve it?
The above screenshot is from a personal edition. It should be visible.
Do you mean to have an option to Record test case while running a case in the portal, I don't think that OOTB would provide it.
