Assignment End
when an assignment end whether we want to save in DB?
how to cancel the assignment being saved in the data base?
When an assignment is completed it automatically stores in the database.
What do you mean by cancel the assignment being saved in the database? Can you clarify?
Thank You.
HI,
Once the assignment is completed, auto commit is triggered and there is no way the assignment can bypass the DB commit.
If you mean that the user may review the assignment form once and then submit it else cancel it, that cannot be done. Instead you can provide an optional edit after the review mode which will override the data already being committed previously.
Faizan.
Hi Yatish,
If you don't want to save the case in the database you can create temporary case.
Please refer the below links to know about temporary case:
https://community.pega.com/sites/default/files/help_v722/procomhelpmain.htm case
https://collaborate.pega.com/question/declare-expression-temporary-work-object
https://collaborate.pega.com/question/how-create-temporary-cases-through-pega-api
Vikash
