Show test id field
How can I add a test id field in an button?
Because it doesn't appear and I can't inclued this button in a test scenario record.
i attach an image
Tks
***Edited by Moderator Marissa to change type from General to Product, added Product details and Capability tags***
@ArturoTG Is this button in any pega OOTB section?
As per your screenshot, the control is pzActionButton for it which ideally you should not use.
Check the parameters tab of it , if there is an option or else change the control to use latest button control
Regards
Bhavya
