Cisco Systems
Cisco Systems
Cisco Systems
Posted: Sep 25, 2017
Last activity: Sep 27, 2017
Last activity: 27 Sep 2017 12:24 EDT
Mapping of Incoming Response from a Connect-REST failed
We are trying a consume a REST Service through connect-REST, Whenever we are sending a huge payload in the Request, we are getting the below response and error:
When the same request(with huge payload) is sent from a REST client like POSTMAN, we are getting the right JSON response.
Response:
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"> <html><head> <title>414 Request-URI Too Large</title> </head><body> <h1>Request-URI Too Large</h1> <p>The requested URL's length exceeds the capacity limit for this server.
</p> </body></html>
Error:
** Error mapping incoming response to <.ResponsePropertyName>: org.codehaus.jackson.JsonParseException: Unexpected character ('<' (code 60)): expected a valid value (number, String, array, object, 'true', 'false' or 'null')
Response:
</p> </body></html>
Error:
Show More
Response:
</p> </body></html>
Error:
at [Source: java.io.StringReader@2f7857d5; line: 1, column: 2]
However when the Request payload is small, The incoming response is rightly mapped and we can find the same on Clipboard.
We found the following solution on PDN and this didn't seem to work:
https://pdn.pega.com/support-articles/exception-thrown-incoming-response-connect-rest
The following error was seen even after implementing the work-around mentioned in the link:
</p> </body></html>
Response:
</p> </body></html>
Error:
</p> </body></html>
Thanks in Advance!
Show Less
Under Apache, the limit is a configurable value, LimitRequestLine. Change this value to something larger than its default of 8190 if you want to support a longer request URI. The value is in /etc/apache2/apache2.conf. If not, add a new line (LimitRequestLine 10000) under AccessFileName .htaccess.
However, note that if you're actually running into this limit, you are probably abusing GET to begin with. You should use POST to transmit this sort of data -- especially since you even concede that you're using it to update values. If you check the link above, you'll notice that Apache even says "Under normal conditions, the value should not be changed from the default."
