Atos Syntel
Atos Syntel
Atos Syntel
Posted: Sep 9, 2017
Last activity: Sep 11, 2017
Last activity: 11 Sep 2017 12:13 EDT
Result condition type in Forking
How can we configure a result value on a connector (from decision fork shape) when there is no Decision table, Decision tree or Map value involved.
The Result field is a text entry box when draft mode is on or when the decision shape is a Fork. This allows you to enter temporary results, even if you have not assigned an actual decision rule to the shape. When draft mode is off, you must associate a decision rule and enter a valid result.If the decision type is a Fork, complete the text entry field with a text that matches the flow action name in the previous assignment.
For example in the below example,
The flow action assigned is Create. So the connector chosen by the fork would be the Create connector and thus the Approve flow action gets processed.
Gisela
