Jeeva Shanmugavel
Last activity: 19 Jul 2017 5:44 EDT
Association Ruleform Differences - Filters and Class Join
Association 1 - pxCreateOperatorInfo
Association 2 - pxAssignedOperatorInfo
The first association rule has Filters and the second association rule has Class join. Why is there a difference in the ruleform in Data Access tab? Also, if you see Pages and Classes are missing in the Ruleform for Associations with filters. There is no option to choosse between the two while creating the Association rule.
This rule form was enhanced to support join with multiple classes to make it similar to report definition experience. I believe there is a property to maintain (pxRuleCreatedVersion) which controls this behavior internally. All the new reports created on or after Pega 7 versions should support newer association rule form (i.e. Association 2).
Let us know if this helps.
